- Thank you received: 6
Local Bearings Source?
- RadioFlyer
- Premium Member
4 years 2 months ago #508
by RadioFlyer
Local Bearings Source? was created by RadioFlyer
Is there a local source of name brand bearings (SKF, FAG....) that someone can recommend?
Thanks,
Mike
Thanks,
Mike
4 years 2 months ago #509
by tskucher
Replied by tskucher on topic Local Bearings Source?
I’ve had good luck with Applied Industrial Technologies on Campion Street, as well as Mearl’s Machine Works on Richter.
The following user(s) said Thank You: RadioFlyer
4 years 2 months ago #523
Replied by brianbrowning on topic Local Bearings Source?
If you know your numbers, I've had good luck with Lordco. Believe it or not.
- RadioFlyer
- Premium Member
4 years 2 months ago #524
by RadioFlyer
Replied by RadioFlyer on topic Local Bearings Source?
Thank you. I will check it out.
- RadioFlyer
- Premium Member
4 years 1 month ago #576
by RadioFlyer
I went to Applied but they only sell to businesses. I was able to get the wheel bearings I needed over the counter at Mearls.
4 years 1 month ago #580
by tskucher
Good to hear that you found them at Mearl’s! That must be a relatively new thing at Applied because I’ve purchased bearings from them for personal use, though it has been a few years.
